Install conduit in foundation for future use.
bad_idea
Pasquotank, NC
Building a 30x40 garage w/ block foundation and concrete slab, 2x4 walls, and vinyl sided soon. Will hire out the concrete work and build the rest of the garage myself. I am not running any electrical at this time. Want to get it up and water tight, then invest that money/time to add the electrical. I would like to run a conduit through the foundation now for use later. Plan on a 100 amp service to the garage from the main panel on the exterior of the house 18' away. What size conduit and how deep to bury it? Will be a block foundation w/ 2x4 wall, do I punch the conduit through the bottom plate or do I have it enter on the inside of the wall, missing the bottom plate all together? Do I run the conduit all the way into the electrical panel (do not plan to finish interior walls for several years) or just punch it through the foundation?
Please don't beat me up about hiring an electrician, I will when I get there. Right now I just want to punch a piece of conduit in for later use. While I'm at it, would like to add another piece of conduit to run a PEX water line into the garage down the road.
jetnow1
CT.
Larger conduit is easier to pull the wire thru, avoid sharp curves, don't forget to install a pull string and the special fitting to allow for movement from frost heaves. My electric
comes up next to foundation then runs thru the wall, I used 2 inch conduit and it was
tough enough to pull thru, but I had a couple of 90's to get thru. You can just put a plug or cap on the conduit if not installing the power for a long time, but your building inspector might not like it, may thing you are planning to do the electric without an inspection. If you run it outside and cap it might be an easier sell to him.
Kaizen
New England
I also thought of doing this and my concrete guy talked me out of it. Not only a pita for him but not needed. As said above just come up the outside and through later. What you should be thinking of is if you want any floor boxes inside or need water/drains. FYI tying into your house brings lots more codes so I did not.
bimmer1980
York, PA
OP--In my opinion, this is a great idea, but then I actually did this for my garage. I was pleased with how it turned out....
I had a 42 slot main panel (actually a sub panel fed from the house) that fed to three smaller sub-panels on each wall of the garage. This shortened the run to a few circuits on each of those walls.
The pictures I show are from mid process. I haven't uploaded the completed pictures.....
NOTE--in the fourth pic, it looks like a disaster...there is a temporary sub panel for utility outlets and welder circuits while I do the permanent wiring work....
I did all this work myself. I'm not a pro-electrician....
However, the inspector did pass all of my work a couple of weeks ago, so that might count for a small amount....
Let me know if you have questions....
maxpat82
Depend on your frost line.
here in quebec: 3' so my conduit go through the footer at 4' deep
I went with a 3" electrical pvc. I don't plan to run electrical trough it...garage will have it's own connection to the electrical network. but there will be room for it if need be.
I will hold only a water line and network for now.
and a 3" abs for the floor drain to connect to the spetic when need be. (Only 12" deep through the frost wall.... because of the slope needed :|
readhead
Durango, Co.
My area requires a disconnect mounted on the outside of out buildings so there is no advantage to roughing in a conduit. You might want to check to see if there are similar requirements in your area.
Falcon67
Merkel, TX
I used 2"
readhead
Durango, Co.
Falcon67, I get so jealous when I see foundation prep like yours. Up here in snow country I would have all the concrete in your entire slab in a couple of footings.
Falcon67
Merkel, TX
Believe me, I know we are fortunate in that regard. Down here we just slap down some 'crete and throw a building on it.
Bert_
NW Iowa
Stick a 2" up inside the wall for electrical. Run it through the plate if you will recess the panel or just inside the wall if you will surface mount the panel.
Same thing for water except it shouldn't be in the wall if you get below freezing. Use electrical 90's.
Think about any other locations in the building where you might want water or electric.
This can make a MUCH cleaner install though it does take some planning.
matt_i
I would run 2 conduits, another for low voltage like Cat 5s, or interlock wires for security.
I would also suggest the 2". The conduit is tougher/stronger as it gets bigger and also easier to pull thru due to the larger radius sweeps. Definitely put some type of moisture resistant rope into the conduit as you assemble it, this will really help out later.
TractorJeff
Elkhorn, WI
I told the Building Inspector that the pipes are for the future Owner! I retire in 5 years and may or may not stay here as it gets cold in the winter. Having the piping internal keeps the water from freezing.
