Hi guys this question is not about my garage but there is alot of knowledge here so hoping someone can help.
I have a property with a crawlspace and the plumbing (pex) is protected with heat traces like these: http://www.canadiantire.ca/en/pdp/pipe-tracing-heating-cables-0522584p.html#.VKcHT4EhzqA
Problem is one has failed and there is no acess to that perticular line. Im thinking about getting a heat trace and securing it inside some 2" pvc drain line and then cutting the two pex lines and sliding the pvc (with heat trace) over the run i cant reach. So ill have a 2" pvc pipe with 2 pex lines and a heat trace inside.
I think this will be an easy fix and will work fine to prevent freezing. But will the wires get too hot inside the pipe? If they get too hot will they be a fire hazard or simply risk burning them out? Dont want to burn the place down. Any advice?
