Installation help for Maxlite LSS2XT8USE4803
mrmineo1
Pittsburgh PA
Installation help for Maxlite led light fixture
I am getting ready to redo the lighting in my garage and I bought the Maxlite LSS2XT8USE4803 "the best light fixture ever" and cant seem to find any information on whether or not I can "daisy chain" the fixtures together. There is no attic above and pulling the ceiling down isn't happening. Surface mounting the wiring is going to have to be the installation method. I am running 2 rows down either side of my garage, each fixture is 6 inches apart. There is a knockout on either end of the fixture. Do I have to put a junction box with an individual wire to each fixture or can I just make a junction inside the fixture to attach to the next light with a pigtail going to attach to the fixture wiring. It wold seem silly to put a junction box and have a separate wire to every fixture come out of that box. Thanks for any help.
Knight511
TX
The picture looks like there are knock outs at the end of each fixture, so you can knock them out to run the conduit light to light.
PoorUB
Fargo, ND
You should be able to **** them together and run 120 volt from one point, through to each light. Worst case you may need to space them out and put a short conduit in between.
HeavyD1
I am using 4ft of EMT between the fixture, 4 row of 6, using the fixture to contain the wire connections. I did contact Maxlite and they confirmed that the fixtures are not rated as a raceway for other circuits (I wanted to run a circuit for a garage door opener through them).
