dont post much here, but thought i would share this..
i went to menards yesterday and bought a Soleus 5000w heater, 2 yr warranty for like $220.. i got it mounted and wired up.. i plan on installing a little cheap 2 pole line voltage thermostat later on..
this heater only has an on/off switch.. i used an old tv hanger mount and used it.. you can mount this unit with a lag screw using the smaller black bracket on the perimeter...
i got it all wired up and let it run for a bit, seems to run good and quiet, puts out alot of heat for it's compact size..
i have a simple video of the unit mounted with it turned on and running, i'll post it here in a minute..
i bought it at Menards so i could physically see it and if something happens i can exchange it rather easy..
