HoosierBuddy
When I built my garage in 2006, one of the things I thought to do at the time was run a network cable into it. You may remember that in 2006, WiFi wasn't "all the rage" so, the original goal of the network cable was to hook a PC up to my network switch someday.
Fast forward 6 years, I've never used the network cable for anything. The old network switch on my home network was trashed out long ago when we upgraded the house to DSL using a Westel wireless router. The Westel doesn't do a good job of covering the whole house though...so I finally bit the bullet and bought a Netgear dual band wireless router and hooked it up to the empty network cable in the garage.
Now I've got full wifi in the garage and more of the house has a signal.
The only real issue I had was trying to setup the G-band section of the router to the same SSID and Passphrase as the existing wireless. I couldn't make that work at all. I finally just reset the thing to factory defaults so my iphone and laptop would see it as a second network. Seems to work fine, even though it's a bit of a kludgy setup, with a wireless router plugged in through a long network cable to the old Westel (The Westel is a combo dsl modem/router/wireless access point.)
Phil
Phil
There's at least one network jack in the important rooms in the house (bedrooms, living room, dining room) but sometimes as many as 4. All the tv's and game systems hook into that. I have a dual band wireless router with WPA2 security for us to use and then a separate guest wireless network with WPA2 that has no access to any network resources.
