I just built my new garage and need to install a 200 amp service. Have some questions about install. I am installing the meter socket opposite the panel. I plan on running from the mast head outdoor cased wire into the meter socket through a rubber seal that clamps down tight when you tighten the nut and further sealing it with silicon just incase. I plan on coming out of the meter socket on the bottom and running the wire through 2 inch conduit into an LB and through the wall. On the other side of the wall i plan on connecting the LB outside with an LB inside and running it into the box on the bottom all through conduit. Other than it being tuff to pull and bend that wire does anyone see a problem with this?
