I recently set up a DV 7.5hp compressor, which is used primarily to run an abrasive blast cabinet. The "issue" I'm having is that even with the largest nozzle option the manufacturer offers and a high pressure setting, the compressor has no problem whatsoever keeping up with the output, so it stops and starts frequently during use. The motor has a somewhat hard start due to the phase converter being a little undersized (the manufacturer changed the rated recommendations in later revisions), so I'd like to avoid frequent starts if possible.
I've read that electric compressors can be used with a pilot unloader valve like a gas compressor, allowing it to run continuously and bleed off excess pressure. What I'm unclear on is how the valve would be physically installed on an electric compressor, since the existing unloader valve is much smaller, and actuated internally by the pressure switch.
www.rolair.com
How It Works: Piloted Unloader Valve - Rolair Systems
Learn about piloted unloader valves and how they work though this explanation of their components, and adjustment process.
www.rolair.com
