Installing gas line question
Aldershot
So the weather warmed up and I decided to in stall my gas line , when I put my risers In at the gas meter and at the garage should I put a 3 point swing joint or 4 point swing joint for frost what is better
jonjon1
3 elbow swing joint....
If you are putting ball valves get outdoor rated units, I always but isolation unions and paint everything with POR15 , tracer wire and gas alert tape is also a must around here... which looks like you have under control...
A
Aldershot
Yup I have two outside valves going in one by gas meter one at garage when its all installed going to test it at 15 psi for a day to make sure no leaks and and ur right I have tracer wire and danger tape in ,but what kind of paint is por15 is that like a trim clad rust paint
jonjon1
Yah, the por15 is in my experience one of the only ones that doesn't have to be touched up and rust through, plus you dont have to prep anything much, just wipe them with brake clean, and brush the stuff on {after its all psi tested and perm}. The sun changes the black a bit but it NEVER rusts through... Plus I like brushing vs spraying when on the side of a building.
CNGsaves
KS and OK
Above advice has got you covered OP.
Couple questions . . . . Where located ?? How long is run ??
Only suggestion is put bed of sand in bottom of trench and at transition points where risers come out so the effect of freeze/thaw won't be moving pipe around as much.
Are your risers Stablock or you having them fused ??
like2wheel
On an as needed basis
Looks like the gas company's done away with swing joints.
I know this is an old thread, but I'm wondering if this is true.
I plumbed an elbow off my meter, & would like to send it straight down to a shutoff and a union on my riser for the poly gas pipe to my pole barn.
Space is kinda tight for a swing joint.
