axeman713
Hello all.. longtime lurker. I bought a house and I am trying to renovate the garage. Garage is on a slab, separate from the house. I have SO MANY questions!! If you guys could provide me any advice you have, I'd greatly appreciate it!
1) New garage door - I'd like to reinforce the corner of the garage next to the garage door opening since I live in southern CA. It seems like it should be braced better to resist a side to side motion. I was going to install diagonal 2x4" inbetween the studs, and then put 3/4" plywood to tie the studs into the header better (from the interior side). What do you guys think about it?
2) Insulating the walls - I'd like to insulate and drywall the walls. The garage siding is just wood planks nailed from the exterior without any building paper behind the siding and the studs.
I'm assuming I cannot just install insulation in the wall without building paper between the insulation and the wood siding, correct? Since the siding is already installed straight to the studs, what should I do?
Should I just cut the building paper and staple it from the interior of the garage and then install the insulation over it? Would that be sufficient enough? Do you just use regular staples and staple gun to attach building paper to the studs?
3) Framing in rear 8' garage door opening - The garage has a 16' front entrance, and a 8' back entrance. We never use the 8' back entrance and I'd like to just frame it in as a wall. I'm assuming since the garage was structurally built to have an 8' opening in the back, that I can easily build in a wall instead? Anything special I should know before doing this?
4) Re-locating 32" side door - I'd like to move over the side door a few feet so the entrance isnt right next to my car. The current door frame seems like it was hacked together and it doesnt really fit right. It hangs over the edge of the foundation and bugs can crawl in; it's not a very good seal.
How do I properly install a pre-hung exterior door a few feet over from the existing opening? The part that confuses me the most I guess is the prehung doors seem like their frames are wider than my garage wall.. so what do you do? Do you cut the edge of the pre-hung frame to be skinnier?
What do you do about the bottom of the door seal with the slab? Is there a piece of trim or something you buy to seal with the floor?
5) Top plate 2x4 crack - Right near where this 32" side door is to be relocated, the "top plate" of the frame structure has a crack in the wood. How do I fix the crack? The top of the wall has 2 layers of 2x4" that meet with the roof structure. it's the top of the 2 2x4"s that is cracked. Do you think I could just glue and screw the wood back together?
6) Cracked foundation - The slab has a large crack running down the center. I have had a few people tell me it was likely caused by lack of gutters/drainage outside of the garage? Does this sound correct?
What is the process for me to fix this large of a crack? I'm assuming I have to cut a ~2ft channel and fill it with rebar and repour concrete in there?
7) Painting the ceiling - Suggestions on how I could paint the ceiling white? I'm thinking buying an air compressor for the job. I'm thinking of painting the ceiling white and leaving the trusses exposed to leave the room nice and open? What do you guys think?
If I wanted to drywall the ceiling w/ the peak of the garage and leave the trusses exposed, how could I make these trusses look more aesthetically pleasing? How could I hang drywall on ceiling? Would I have to reinforce roof w/ 2x6" before hanging the drywall?
Album of images (I dont know why they wont stay in order):
http://imgur.com/a/WRJXB
