TrickVert
Well, after lurking and searching (a lot!), I'm getting started on finishing my 2-car detached garage. I'm planning on using corrugated galvanized metal (1-1/4" x 1-1/4" ribbing) for the ceiling, and about 3.5' up the walls, and finishing the upper portion of the walls with OSB (painted or cleared -- I'm not sure yet which).
I'll be adding plug-in fluorescent shop lights and will power those via surface-mounted outlets in handy-boxes using 2" ******* to protect the Romex from sharp edges. Easy. What's got me scratching my head, though, is some existing incandescent fixtures (currently ceramic bare-bulb units) that I want to keep for in-and-out trips, and already-mounted outlet boxes (four of them). The boxes (for lights and outlets) are a mix of blue and black plastic ones, all mounted with the expectation of drywall being used as a ceiling material.
One thing I thought of was to keep (and extend?) the existing boxes, and perhaps use some of the OSB to make a flush-mount "plate" of sorts.
Alternately, I might just cut down the existing boxes so they are flush with the ceiling joists, then add handy boxes right below. My concern here is there may not be sufficient extra wire to reach a new box. There should be, but I've seen some with only a couple inches of slack. I also want to keep the incandescent bulbs as high as possible.
Another idea is to cut a square hole in the metal, and build a frame (prior to installing the metal) and attach some OSB, effectively recessing the boxes. I saw in another post where someone recommended THIS to fill the gaps. This would be OK for all but one which is a switch for the "attic" lights. I'd be worried about sharp edges when using it.
Any ideas, examples, pictures will be appreciated.
Thank you!
Thank you!
