I did not tell my builder to put mounts for motion sensor security lights in the soffits on the corners - so I am going to add them.
My main question is - How do I get these soffit panels out so I can mount a support for the light.
I thought these panels popped out, but they seem to be in there pretty tight.
Do I have to peel back the fascia to get these out? Looks like they might be nailed in. (pic below)
Thanks
You might be able to lightly bend the lower L part of the fascia to gain access to pop soffit out.
You could try to bend the lower L part of the fascia and run a utility knife along that inside bend, then bend back and forth to snap a section off/out and then bend a new L piece of aluminum to slip up under the existing fascia and nail back in through bottom.
Could use a nail punch and drive the current nails holding the fasica to the board thru, and then remove that piece. Do your work and bend a new piece of aluminum fasica to put back in place...knowing the new stuff will be clean/shiney and wont match existing. Just about anytime we did this kind of work I'd bend all new for the entire length so it all looked new again.
The soffit will be attached with either staples, nails, or screws..you wont know until you expose the ends of them at the fasia board where they are attached. It looks like vinyl soffit in the picture, and if so it has the typical hook like vinyl siding has onto the adjoining piece...you just slid it back to unlock it and remove the panel, really nothing to it.
