Installing Patio Door/deck in loft garage
jack anderson
Central Pa
Greetings,
I am planning on installing French Patio doors in my 30' X 28' 8/12 pitch loft truss garage. I will be building a carport deck as well and I wanted to know if I need to take off the sheet metal siding prior to installing the patio doors or if I could mark the siding from the inside to indicate where to cut the opening? I would love to hear from anyone who has a garage with loft trusses that has created a similar concept. I am under the impression that the best way is to remove the siding first.
The Fishjuggler
little d
NW Oklahoma
Jack, your going to have to trim out (j trim) around where the brick molding is going to go on the out side. It can be done without taking the siding off but, I think you will find that it is easyer and will be a cleaner looking job if ya take it off.
