installing retaining rings
bluesboy
new york
Anyone know a trick for installing retaining rings. The kind that look like a lock washer. To hot to be chasing it around the shop. What are this type called?
Thanks Jim
Shadowdog500
Down the shore
I can think of a couple that may look like a lock washer.
You have a photo?
If the item is small you can do it in a really big freezer bag so the clip don't fly across the room.
Chris
bluesboy
new york
This one is about 1/8 thick with a 5/8 bore looking exactly like a lock washer. Has small gap no over lap and a slight spiral twist. Sorry no photos
spy604
gap or not you should still be able to twist it on, sometimes you may need a hammer and a punch to 'encourage' it to turn
CrashTestDummy
Is it going around a shaft? If so, try a deep socket that just fits over the shaft to use to guide the ring on with the light tap of a hammer. That'll keep it from popping and flying.
Gene Beaird,
Pearland, Texas
bluesboy
new york
That did it. Thanks Crashtest. just the trick I needed felt like I needed three hands. Good to know I can rely on GJ
