I am in the process of wiring up 17 6" recessed lights in my basement woodshop. I know that this will work but is this the "correct" way to do this? Or should I go directly from my switch and wire the lights in "line" instead of branching off? I only ask because this way will be easier and also waste a little less wire.
Thanks.
120v 15amp comes from the breaker using 14/2, goes to the switch, then the current single light bulb. My intention is to run the wire down the existing ceiling cavity, going to the third light, then branching off both directions as shown. Should I do this a different way?
IMG_2555 by Sean Lund, on Flickr
Thanks.
