My nonprofit I work for received a donated compressor. CH 60 gal VT619501AJ.
Date code by the serial #. 01/24/1997
12@ 40 psi
10@ 90 psi
125 psi max
15A 5 HP (says 6...)
The deal is.... it has never been used
Never had oil in it.
OK install plan details:
I need to install in a different location than my horizontal 30 gal Craftsman from the early 80's due to space considerations.
Electrical: 10/2 MC up and across the shop and then 1/2 conduit down with (2) 10 AWG THWN & 12 AWG THWN (ground) into an AC disconnect. Then MC whip to the compressor
Plumbing: Here's my question. The compressor has a 3/4 out hole. I came across a 3/4" Rapidair filter/regulator combo and am thinking of running 3/4 all the way to the hose and eventually running 3/4 Rapidair Maxline plumbing so I have air at both shop overhead doors. Not a big shop-40' square maybe.
Filter/Regulator: http://www.northerntool.com/shop/tools/product_200625244_200625244
Plumbing kit:http://www.northerntool.com/shop/tools/product_200484023_200484023
Catch is so many are going with 3/8 or 1/2 lines and filters. I want to do this once so even if we replace the compressor the system will handle a slightly larger capacity.
What say you? 3/8", 1/2", or 3/4. Price is relatively same in the scheme of things.
Thanks!-Mike
12@ 40 psi
10@ 90 psi
125 psi max
Never had oil in it. OK install plan details:
Thanks!-Mike
