I'm building a new home in central Iowa. The house will have a 1780 sq ft garage attached. I'm not going to put radiant heat in the floor, but I will insulate the garage with fiberglass batts in the 2x6 walls (about R19) and blown in cellulose (R40) in the attic. I plan to use an overhead Reznor or similar gas heater.
My question is, will I get any significant benefit from putting 2" foam board under the slab even though I'm not using floor heat? Will the foam board make a significant performance difference or make the slab warmer even without the floor heat?
If it matters, the back 14 feet of the garage (shaded in red in the attachment) is where I will do most of my work, it also has pre-cast under the slab because there is a 14x30 under-garage under that part. The under-garage has insulated walls but it will not be heated.
