Insulate Interior Wall
Davey4000
Jefferson, GA
I'm planning on insulating the perimeter walls of my detached garage using batt insulation with vapor barrier. I also have an office and therefore an interior wall. I want to insulate it because the office will be heated/cooling all the time while the garage part will not. It should be ok to insulate the interior wall with batt insulation "without" the vapor barrier shouldn't it? There will not be any car-washing going on inside.
boiler7904
NW IN
I'd say that you should put the vapor barrier up on the office side of the interior wall. If the garage isn't a conditioned space, the interior wall will really perform just like an exterior wall from a thermal and moisture stand point.
fefarms
Vapor barriers are generally over-used. They make sense in severe cold climates like North Dakota, Upstate New York, Canada, etc. They stop the diffusion of water vapor from the warm, humid interior to the cold, dry exterior. At 40 below zero outside, with 10% relative humidity, there is a sizeable vapor gradient across the wall.
In Florida, or Houston, TX, they stop the diffusion of water vapor from the humid exterior to the drier, air conditioned interior. The vapor gradient is not nearly so great as the severe cold climates, however.
In moderate or maritime climates, vapor barriers make little sense. In winter time it is often more humid on the outside than the inside. There is no vapor pressure gradient trying to push water vapor through the wall. The vapor barrier gets in the way by preventing the wall assembly from drying to the interior, in the event of rain penetration, for example.
Air barriers are important in all climates. Leaking air will transport far more water vapor into a wall cavity than diffusion ever will. That's why drywall, plywood, etc should be applied and carefully taped and sealed to both sides of the studs.
For a garage-to-house wall, I'd use unfaced batts unless the garage routinely gets down to 10 degrees or less at night. I bet it rarely gets below freezing, unless you live somewhere really, really cold.
astroracer
Mid_Michigan
Check out this stuff:
www.p2000insulation.ca
I have been working with it for a couple of months now and I feel fiber batt insulation is past it's usefulness. This stuff performs so much better, without the loss of R-value at the dewline, and it's so simple and easy to install it just isn't funny. Check it out, if it didn't work I wouldn't be here telling you it did.:thumbup:
I'll keep pushing this stuff until you guys tell me to shut up.
Mark
