Working on insulating the upper part of garage/pole barn now.
Thought I had made up my mind on using Styrofoam in the ceiling.
BUT after crunching numbers etc, it may be more cost effective to have someone spray foam it.
I will start getting estimates, but before that I wanted to pose a question.
Should I have it sprayed in the rafters on the vapor barrier or figure out a way to put it on the actual ceiling (if it had covering on it)?
Right now everything is open beams.
If I put it on the ceiling it will take a bit more prep as they put the trusses on 8ft centers, so there will have to be some grid work done..
Will I really notice alot of difference between doing the rafters instead of the ceiling?
I do like the option of having a little more overhead to work with in the center of the building.
BUT it's not a huge problem if I don't.
Thanks,
BTI
Thanks,
BTI
