My Dad's 2.5 car detached garage was insulated with fiberglass rolls and then plastic vapor barrier (5 years ago). Which is all covered by OSB now. Garage is now heated (Last 2 years) never below 50 degrees F. The problem is there is a lot of moisture in the roof insulation. Does the roof insulation need vapor barrier as well? Have spent the last two weekends pulling down roof insulation and installing dura vents. There is currently soffit venting but no ridge vent. Will adding a ridge vent in spring fix this issue?
or do I look for solar powered soffit vent fans? Any information would be appreciated.
