JP, it doesn't quite work like that as far as duct size goes.
I knew it was not a simple matter, and that's why I am here to get expert/experienced help. Thanks Jamie V for your help so far, and for any more to come.
Do you have any info on the unit besides the outlet size? Do you have any fan specs?
From the installation manual: (BTW, this is a Carrier Infinity 15 SEER, model 48XT-A360903-TP) Fan Nominal Airflow (Cfm) Efficiency: 1050, Max: 1200, Gas Heat(Low Stage): 875, Gas Heat(High Stage): 1410. Fan size 11" X 10". Motor HP: 3/4. Required Filter Size: 24" X 30" X 1".
Ductwork sizing isn't as easy as just square inches. Air isn't like water where you put a gallon in and a gallon comes out. You can create enough turbulence that no air can come out (that's kinda hard but you get the idea).
Are you making the ductwork out of sheet metal then insulating it?
I was planing on using 34" thick foil faced foam board, rated R5. Gluing the joints and then sealing with foil tape. Tape is Nashua #322 HVAC Tape.
To be the most efficient when the ductwork turns it needs either radius elbows or turning vanes if square.
I knew about the turning vane, just didn't know what it was called. I planned a piece of curved sheet metal at the bottom to turn the air flow up, and another at the top opposite the 16" round takeoff. In my mind this vertical section is sorta like a plenum, but since it is much longer in one dimension, I feel like it is more like a duct.
Round ductwork (not flex) is the most efficient way to run it.
If round is the most efficient, should I just get a square to round transition (or use a round takeoff at the unit) and use two elbows?
And you also should reduce the size of the ductwork after every so many outlets.
See mental sketch below.
Do you have a rough sketch of what your trying to do?
I don't have a sketch, but I will get one.
Meanwhile, here is a mental sketch:
Pac unit supply and return ducts (rectangular, matching size of openings on the unit) coming through the wall just above floor level. Return air plenum (with filters) on the right, vertical duct (of whatever size and configuration we come up with) on the left. Goes up about 10-12' where it will connect to the horizontal 16" round pipe. I also have a 16" to 14" reducer and some 14" pipe. No outlets are planned for now, I just want to get the air to the far side of the shop from the return to create circulation. I have enough 16" pipe to get just a couple feet past half way. I have a walled off area with no ceiling for parts/tool storage, and a small bath room (with a ceiling). Plans call for at some point adding another small room for an office/break room. At that time I will put a insulated ceiling over that area, insulated walls to the roof of the building, creating a un-conditioned attic that will reduce the volume of conditioned space. I will also then add outlets in the ceiling of each of those rooms, and add the 14" pipe to the end of the main run, if necessary to push air into the rooms.
