Insulated subfloor
My nephew bought a fire station !
He is contemplating installing radiant in-floor heat by placing a subfloor over the existing concrete floor (10"-12" slab, no vapor barrier or insulation underneath). For the most part this will be one big (2,00-2,500 sq ft) heating zone. The commercially available pre-made panels, like DRiCore have woefully inadequate insulation (1.5-3.0 R) and they are expensive.
He was think about laying down 1"-2" of polyiso foil faced rigid foam baord and then 3/4" OSB on top. I have read that polyiso should not be used for this because any moisture that gets under the OSB will be absorbed by the polyiso and can cause mold. True of false
Other suggestions ?
terabitdan
Congrats to your nephew. That should be an interesting project.
I have read on GreenBuildingAdvisors.com that XPS is much better than Polyiso for this since it does not absorb moisture.
ssdave
Eastern Oregon
Terabitdan is right on. Do not use polisocyanoacrylate foam under a floor. Use 2" of XPS for a R value of 10. That's quite adequate for a floor. Put 6 mil plastic under the foam to insure that moisture doesn't wick up from the concrete.
