mobiledynamics
Chase *******, EMT Squeeze Connectors, etc, etc.
Where is a Insulated Throat Fitting advantageous to use versus without.
More of less, the ID of these fittings are generally smooth regardless.
I guess the same ? goes for Plastic Bushings.
I've run plenty of BX forever and some odds and ends conduit.
I've generally used the anti-short bushing - on larger IDs/OD, I'll double up bushing, overlapping the seam 180.
Plan to run some conduit here and there....
Was not sure when is it best to use said *above* fittings when applicable
