Insulated Window Header Construction??
C-S-H
So your suggesting king studs from bottom plate to top plate?
Yes. 2x6 king studs, then 2x6 cripple studs on the header (or under). The sheathing will want to carry the vertical load in shear from the cripple studs to the king studs. So correct header would be a triangular truss that would be stiffer than the sheathing. We rarely do that. But this wall is not ordinary platform frame construction either.
N
NWOhioChevyGuy
Buckeye Hill (Morenci, MI)
I will post pictures of the floor joist and second floor structure once demo is done.. (2 weeks out yet)
On the second floor there are two double hung windows in the wall. Roof line is a “flat” low pitched roof that bears on that second floor wall.
Father in law will be assisting in the structure / 60+ years of licensed construction experience.
Hank11
Tennessee
Span the header and wall junction with your sheathing. Nail it thoroughly. You could also add strapping over the header and fixed to both sides of studs. What you don’t want is a hinge. At the ends you will have king studs — nail this well.
In specifying this, I would pretend the beam is a header for a garage door or similar - in other words “air underneath”.
A photo or drawing would be a good idea. An engineer might be needed too.
billconner
Thousand Islands NYS
ran across this
N
NWOhioChevyGuy
King studs will be fastened properly. I will glue up the header assembly as well.
I will add the strongtie header brackets also.
N
NWOhioChevyGuy
Ended up not doing any cap or bottom cap - ran out of room.
Wall is sandwiched between my new garage build and the brick corner of my house which is dead plumb and straight. (Shocking for a 159 year old house)
Was originally a cooking porch turned into a kitchen in 1914. See the roof line on the back brick wall that was the original roof of the porch.
Space is going to be AWESOME when completed.
PCustoms
VT
Are you adding more studs to those bays?
billconner
Looks very nice and well built. Congrats!
N
NWOhioChevyGuy
Any issues with the FrothPac? Looks like it filled the cavities nicely.
FrothPac worked great, other than one fan tip popping off unexpectedly.
I had some cans of Kraken foam that I utilized to make up the small amount the FrothPac didn't cover.
I had around 670 board feet to do and it was a 620 Kit.
I would use the FrothPac again if ever needed.
N
NWOhioChevyGuy
When the kitchen is 100% complete, I will do some before and after pictures.
HUUUUUUUUUGE upgrade for us and this old house!
Waiting for the custom island table to be delivered & I have to build drawers and drawer fronts for this cabinet and the custom oven cabinet I build for the wall ovens yet.
100% DIY with some demo assistance and framing assistance by a few family members & friends.
Project Started June 1st should be 100% complete by Mid/Late August.
loganb
Omaha, NE
Awesome work! Assuming both you and the misses are loving it? Really like how you did the cabinet and the maple has gorgeous figure
