The_Auto_Tech
- Joined
- Oct 11, 2017
- Messages
- 180
Figured I'd just start another thread regarding insulation in my garage. It's approximately 15x27x8. Currently just has OSB walls with no insulation and open rafters. We replaced the roof sheathing and shingled the roof about 6 years ago. I use the overhead space to store stuff. It's been nice to leave it open so I can fit larger items through the rafters up there. I'm debating what I'd like to do about insulating the place. I'm not wanting to drywall the ceiling or the walls as I like having OSB walls to hang various things on, plus I don't have to worry about damaging it since this is a shop space.
From what I read I don't want to insulate at the sheathing because the roof needs to "breathe" otherwise it'll create moisture on the sheathing and roof and rot the roof. From what I understand I'd need to insulate at the rafters. I'm curious about maybe just using foam board on the ceiling, that way I can still use the overhead area as storage. I guess I could maybe screw paneling to the ceiling and then insulate on top of that between the rafters and then lay OSB on top of the rafters so I can maintain my storage area, but that seems like a lot of work as well.
I just know that the ceiling right now is the most important place to insulate as the heat is rising and going through the roof. What would you guys recommend?
