Been reading here a bit and ya’ll seem like a smart and knowledgeable group! I’m a decent woodworker (more furniture than home building) but could use some input on insulation and AC Stuff.
I have a long and narrow garage — probably built around 1925 or so. The front 2/3 is storage + workshop, and I’m slowly turning the back third (about 11.5x14) into a craft room / part-time office. I’m in the LA area so fairly dry and warm in the summers. No freezing temps. Right now the structure is completely uninsulated so it is pretty miserable in the summers.
Long term we might turn the whole thing into a more proper back-house, but for now I’m looking for a bit of a temporary improvement and figured insulating the walls, adding (and insulating) a ceiling and sticking a mini-split in would help. I was thinking just un-faced fiberglass batting.
The thing is…the back 1/3 has a Dutch gable roof, with the gable end is a lattice. I think I should cover it (at least loosely) to prevent critters from getting in and nesting in the insulation — but there are no other true vents — although the roof to wall definitely isn‘t air tight.
And the “ceiling” joists are the original 2x4s…spanning 14 ft. It looks like there used to be some ceiling material on it, but I’m a bit concerned about it holding drywall up.
Attached is a photo of the space (it had some plywood sheets for earthquake/structural stability — I might keep those and I just put scraps in the other parts), the ceiling above it (showing the gable end) and the old ceiling material (in case anyone knows what it might be).
Also any input on order of operations? I figure 1. run electrical for HVAC 2. insulate 3. wall it in (ceiling first) 4. Paint 5. Install Mini-split.
Sorry for the ramble…
