absintheisfun
- Joined
- Feb 7, 2010
- Messages
- 84
Just bought a place with an epic 40x60 red steel shop. The previous owner had 2 inches of soft cell foam sprayed on all walls and ceiling. I want to expand on that as I finish the interior. I'm in Texas so it is hot and humid and I am unsure the best way. My plan is to get 2" rigid foam board and put it up with a small 1"-2" air gap to the foam. I'm then going to wall the interior of the shop with 1/2" or 3/4" osb. My question is vapor barrier....do I need it? Does the foam serve that purpose? Ultimately there will be a mini-split or two and many ceiling fans to keep it cool. Heat isn't as much of an issue, but I will address it if needed in the winter.
Those of you that know about vapor barrier needs, please chime in and let me know the best way.
Thanks
Thanks
