Ryanflathead45
Sorry if this has been asked before, but searching did not turn up the answer I was looking for.
The construction on my pole barn finished awhile ago, and I'm starting to run the wiring, but I'm starting to think ahead to the next steps of insulating and covering the walls with metal.
I had the builders cover the ceiling with white metal, and blown in insulation, so that step is done...
The outside of the girts and posts was covered with a layer of bubble wrap insulation before the metal was installed. I have bookshelf style girts 2 foot on center, so my plan was to use rolled fiberglass insulation with the paper vapor barrier toward the inside of the building. But I have been reading several different things, and now I'm unsure if this is correct. Seems like the more I read the more confused I get...
Another question that has come up is the row is insulation the goes against the floor, is it ok for the fiberglass to lay right on top of the cement? Do I need some type of layer between the cement and the fiberglass??
Last question for now: How is the best way to finish the bottom edge of metal wall covering? Meaning so that it has a nice finished edge, but not like a J channel that will just collect dirt.
Any help would be great. Pictures would be even better.
Thanks in advance,
Ryan
Thanks in advance,
Ryan
