Bottlecapdigger
My question is, is there any reason to insulate on the inside of the concrete wall any more than the thickness of the floor? The floor will also be insulated and with infloor heating. Insulate with 2" blue foam panels that is. The panels come in 2x8 ' and I was going to rip then in half so the top of of the panel is just under the floor surface and go down 12 " . With a 5" thick floor , 7 " would then be below the floor . Would this be ok? .is this insulated low enough? Or would l still lose heat through the wall? We're in Ontario. Thanks. BCD
