Insulating between exposed trusses...advice needed. Pics included
bobforapples
Beautiful Orangeville Ohio
It's -5F today :scared: The polar vortex is in full swing and I'm re-evaluating my insulation plans for my pole barn addition.
I was going to use paper backed fiberglass on the bottom cord and sheath the ceiling with OSB. Heating is a mix of forced air and radiant floor. As I was playing around in the barn yesterday I realized my thermostat was set around 50 degrees and I was comfortable. I'm wondering if I'm wasting time + money.
What if I use white rigid foam insulation against the roof sheathing in-between the trusses? I can cut it to fit tightly and glue to the roof. The top cord is 2x4 so I'd probably use 1.5" insulation. I know the R-value isn't nearly as high as the fiberglass, but will it really matter if the temperature difference is 20-30-Maybe 40 degrees?
and a picture for reference:
Jlbc212
Northeast MA
I vote for 9" thick unfaced fiberglass insulation with 4 or 6 mil poly vapor barrier. If the barn is attached to the house, cover with 5/8 drywall. Otherwise use OSB or 29 gauge ribbed metal roofing panels.
dfiler2
NW Minnesota
Yep, go with the thickest fiberglass you can get, you could use friction fit and tension wires then put on the poly and wall covering of your choice.
DC73
Lubbock TX
