insulating block wall
greenskeeper
PA
25x22 block wall detached garage
insulated the ceiling with R19 and R5 foam board
what's the best method for insulating the block walls without loosing too much space?
I do not heat the area unless I am out in the garage working.
thanasi
Toronto Ca
Im thinking like mine, the block wall is the back wall attached to the house ? its a indoor wall and heated from the inside would you benefit by insulating it if this is the case as my home .
I mean ok by insulating it you will keep the cold hitting the warm block wall (inside house) but will it help much when heating the garage during working inside ?
Is like to know myself from some pros !
Crazyjake8493
Upstate NY
Typically a block wall (like a basement) would be insulated with 2" thick sheets of XPS or PolyIso, then a 2x3 or 2x4 stud wall framed in front of that. Doing the walls this way, you'd only lose less than a foot of width across the garage, which isn't much for a 20+ foot span.
If you do use rigid foam, the only one that does not require a fire barrier is DOW Thermax.
Bretny
Dutchess county NY
This is why i would never build even a block knee wall on a garage. Loose to much space.
