What would be the best way to actually hang the insulation? I’m not framing out the inside like some people do. Also I had 3 extra trusses installed so my space in between each truss is 3’ which means I’ll be having to trim, which ***** but oh well. Was planning on using the 1” foam with the foil backing. Maybe double bubble behind it to act as a radiant barrier, I think that’s the correct term. Am I going to have to use an adhesive to stick the double bubble to the wall in between trusses then adhesive the foam to the double bubble?
