Hello, I was hoping to get some advice regarding insulating a ceiling/attic. Specifically the question is to address a problem of too much moisture during the winter months within the attic of the garage. I live in Minnesota so winters are cold.
Let me lay out the situation
Detached 21x21 garage
Gas heater
Normally keep it at 50 degrees Fahrenheit in the winter (again Minnesota)
Walls insulated (kraft backed insulations) and sheetrocked
Ceiling insulated (no vapor barrier) and sheetrocked
No tape or mud (this is changing for the walls)
Vented Soffits
No other ventilation (this is also going to change. Likely I'll be putting a fan up there)
This is what I'm considering doing
- Putting a plywood ceiling over the current drywall ceiling (I ordered marine-grade plywood)
- Before doing the plywood, I'm going to mount 2x4 to the ceiling and they will cover the gaps on the existing ceiling drywall that normally would be covered by tape and mud.
- So there will be a grid-work of 2x4s on the ceiling over the existing sheetrock.
-Within the "voids" of this grid-work I will put 1.5 polystyrene insulation.
-I will then mount the plywood to the 2x4.
If you are asking why I'm doing the 2x4s it's for two reasons. One: It will make mounting the plywood easier. Because there is existing drywall, finding the truss joists will be slightly more difficult and when using 45 dollar a sheet plywood, I'd like to avoid putting extra holes in the plywood. Two: I will use that 1.5 inch gap as conduit to run electrical for a few more lights. This will prevent me from having to get up in the attic, or routing wire on the outside of the plywood.
In general the main reason I'm doing this is to fix the moisture problem. I realize the attic still needs better venting, which will happen. My thought is this will be helpful in creating a vapor barrier, that stupidly I didn't put down when I insulated the attic. It also has the added benefit of looking nice, and creating a simple way to add a few more lights.
Can anyone think of a unforeseen problem this might create? Also, given the added 1.5 polystyrene insulation and marine-grade plywood do you think putting a plastic vapor barrier down would still be necessary? One I would just staple up there? I'm not planning to do that but I'm curious to get thoughts. Also, for the 2x4 grid work, I'm not planning to use treated lumber. Would you encourage or discourage this? Thanks for taking the time to read all the way thru this. If anything doesn't make sense or you need clarification please let me know. Thanks!
Adam
Gas heater
Vented Soffits
Adam
