sort of...What I meant to ask was if in a mild climate like central NC where our frost line is only 12" deep, will there be enough thermal mass in my slab to keep the inside of a sealed and insulated barn above the dew point. I have never owned a detached garage / barn before but the attached garages I own / owned were all insulated and never had condensation but they were climate controlled above and next to them so not apples to apples with my new structure.
Yeah I think no. I suspect the opposite is more likely. Even an insulated slab will probably stay pretty cool all winter in NC.
When spring comes, your slab will probably sweat with condensation. When that day comes the solution is to heat your slab to dry it, by opening your doors, rendering your insulation worthless. A humidifier will work by removing water vapor, but will only work as well as your vapor barrier and door seals allow.
Remember, insulated or not, because it’s unheated, your slab will roughly be the average of the Winter air temp. And depending on your windows you probably wont get the benefit of passive solar heating. So your slab in winter will likely be closer to the daily low temp than the high.
You can do what I do. No need to heat your space in the dead of winter, but when spring comes, it would be smart to plug in a space heater to bring the interior temp up in line with a warm humid day.
No amount of insulation or vapor barrier will stop condensation. The root problems are the temperature swings and that your space is uncontrolled.
I think lowest possible cost and effort would be insulate and heat the slab and only insulate the roof.
