I have radiant floor heat in my attached garage. I used Double bubble on the floor and insulated the wall with 1 inch but didn't go up the foundation wall. So the concrete goes to foundation to foundation.
My question is two parts: I'm building a detached garage and was wondering if anyone ever put down 2 inch 4' x 8' - 250 series Owens foam board under the slab? I already have the 2 inch foam board on the foundation going to sill plate. My concrete guy tells me to leave it and then cut it back to the slab height. He stated, This will stop the floor from wicking to the outside wall. Friends tell me to just put it down on the floor and leave the sides as is. This method the 2 inch foam board is not showing around the perimeter.
Should I have the concrete guy pour the slab with insulated side walls or have the slab poured on top of the foam board (not exposing the foam board)?
Is 2 inch foam board overkill on the floor?
Thanks you for your input!
