TrickVert
I'm working on finishing my 2-car detached garage, and will be insulating the ceiling. Construction is 2x4 roof trusses 24" OC. The garage will only be heated when I'm working on projects, mostly automotive (evenings, weekends, etc.) Heat will likely be a tank-top propane heater or bullet heater if that proves insufficient.
I've finished an "attic" floor down the middle of the trusses on 2x4's that run perpendicular to the trusses. The right third has 7/16 ply right on top of the trusses, the other side is open. So, I go from having 3-1/2" of space to 5-1/2" down the middle (interrupted by the cross-laid 2x4's), to open area.
I'm stuck with using R-13 for one third (unless I remove the ply and jack it up on additional 2x4's), and would have a max of R19 in the middle. Given my occasional use, budget considerations, and "some insulation is a whole lot better than no insulation," I'm thinking of just using R-13 for the whole thing.
Any reason why I should rethink?
(And I do plan on using R-13 in the walls, as well).
Thanks in advance,
Andy
Thanks in advance,
Andy
