bigbearcountry
- Joined
- Feb 10, 2015
- Messages
- 22
I have an attached garage with a bonus room above it. Part of the garage is insulated and part it not. I'm trying to figure out what is the best way to insulate.
The front half of the garage is not insulated and is 10 feet to the ceiling joists. The ceiling joist are built with 2x4's and has 1/2' OSB board above it for storage. The roof rafters are made of 2x4 and has one vent on it near the top roof. I'm thinking of installing baffles under the roof running up from the soffits and putting r13 roxul between the roof rafters and leaving the top open with no vapor barrier for air circulation. Next, I was thinking of installing r13 in the ceiling joists and then adding a vapor barrier to it. After, I would drywall the ceiling.
Would this be an acceptable way to insulate? I want to make warm (I will be heating) and have storage (can be cold) without any moisture or other long term issues.
Thanks for your help!
