insulating garage.
porsche911
Just moved into my house and working on insulating the garage. Just got the wall sprayed today. (not sure if its open or closed cell, perhaps something i should ask the installer)
My question is do i need vapour barrier over spray foam, or can i just put the osb boards right over the spray foam. Im used to doing foam batts where a vapour barrier is required so im leaning towards it, however i do know the spray foam also seals off flow. Would using a 6mil vapour barrier hurt if i used it regardless. Ill be needing it for the ceiling where it'll be foam batts so i figure for an extra $70 or so i can buy a large roll to do the walls where its sprayed.
Thanks!!
JCByrd24
Bath, ME
Where are you located and what are you doing in your garage and heating it with? You don't need a vapor barrier if there is no moisture in your garage. Most climates are dry in the winter and a garage doesn't have cooking, showers, clothes drying, etc to cause moisture. You likely can skip VB either way. Also, OSB on the interior walls is a vapor retarder so again, you should be all set with nothing additional.
gpalmer77
Mokena IL
Neither type needs a vapor barrier in any normal application. Vapor diffusivity rates in open cell are very low, no vapor retardant barrier is required. I researched this before spraying open cell into the roof of my house.
