diggler306
I'm having my heater hung this Friday so I need to prepare by throwing up some vapour and a half sheet of drywall in the corner. I have a hip roof with a relatively low pitch, making space in the corners preeetty tight. I got to thinking that I should probably insulate and do whatever else in that corner beforehand too.
See attached photo. 2x6 rafters. Cold climate. Should I just stuff as much R22 in the corner without worrying too much about soffit venting? I can't even get an insulation vent baffle in there really. The soffits are vented continuously around the whole garage (24x24), so I'll likely still get plenty of air flow elsewhere without worrying about the corners. My plan was do put in R22 batts in the ceiling, R12 in the walls, and then maybe blow in additional insulation after I put in a small attic floor area for storage.
Thoughts?
Thoughts?
