Insulating interior HVAC ducts
Robey5
North of Detroit, Mi
All:
I have seen some people who have put foil-backed insulation over their HVAC ducts to do... something ... here in the midwest.
I am curious about the value of wrapping my duct-work in my basement in hopes to shut it up from the expansion/contraction sounds.
in addition to possibly shut it up a little (it has the cross-broken sides as well) - will this provide any value to the amount of running the heat or AC?
What say you in the GJ?
Done That
MO
In a hot attic...sure. In a hot/cold crawl space....sure. In a conditioned space, I don't think it's worth the effort.
No idea on the noise thing. I might first experiment with some sound dampening squares etc like for automotive use.
NUTTSGT
Northern Central Ohio
My heat duct in the garage from the wood furnace goes up through the unheated attic. I wrapped it with fiberglass then added some Reflectix foil bubble wrap on top of that. It made a heck of a difference in the temps of the heat coming out of the ceiling register.
Enough in fact that I'm seriously considering doing the duct work in the basement this Winter as a small project. I do have a register in the plenum of the main trunk to add some heat in the basement and push it into the crawlspace which is unheated.
Which BTW, I need to clean the box fan down there and move it as it's now 2/3 through November and only going to get colder these next few months. Thanks for jogging my memory.
tab2
Boston
Speaking commercially, it is required here in MA when the duct is in an unconditioned space, even when it is exposed to the return air (in the plenum). I would put money on it helping they system a few degrees.
I think it will help some for noise. Lined ductwork helps more for sound attenuation but that new duct for you, which I don't think it is worth it.
peter2772000
Montreal Can. & Cape Coral FL
If your complaining that much about expansion/contraction noises, makes me wonder what gauge ductwork was initially used. To be honest, the only time I've ever heard duct popping noise was when high static/pressure and very thin-gauge sheet-metal was involved. And IMHO, thermally insulating a duct in a conditioned space is a waste of $$.
An unorthodox solution, but it's worked for me in the past when no other viable/practical solutions were possible. Locate exactly where on the duct run the noise is being created, then either try to pull out the sheet-metal using sheet-metal screws, or, use a hammer and a piece of wood to bash in the offending duct where the sheet-metal is furthest from any joint. I'm not talking a crater-sized dent, just enough to tension the sheet-metal so it doesn't pop any more.
PWC Repair
Arkansas
The plenum right behind my cold air return grill is attached directly to my air handler. It was noisy. I used spray foam followed by cheap dollar store paintbrushes to spread the foam around into a thin layer. It worked great. You can stand right next to the return now and have a conversation.
bobbyjean
hudson valley n.y.
i have become a big fan of rigid foam board since i used in my my garage build-you could box around the offending ductwork with that---gotta seal it up very well i would think to avoid condensation issue's if used for ac...1 inch = r-5..no itch either :lol:
