Insulating Low Pitch Roof
shooon
Dawson Creek, BC
I live in a Northern region that gets extreme cold (-40's) and has pretty brutal winters, so am looking to insulate the attic of my garage to try and obtain an R60 value.
The issue, (I'm thinking I don't know) is I was sold low heel trusses that does not provide much room at all to insulate and still leave room for soffit vent. Towards the edges of my walls where the trusses sit I have 3.5" (the width of the 2x4) of space to insulate... less the 1+ " require to vent the soffit.
I wanted 12' walls with a 4/12 pitch to max out my building height to local bylaws- but I was not aware and did not take into account the insulation issue. The truss supplier did not mention any other options when I ordered them. Is there a way to build a low pitch roof with more room for insulation? or will you always compromise on pitch trying to get the space?
Anyways, I'm stuck with it now. My concern is ice damming on the roof and heat loss due to inadequate insulation. I was thinking of making a bulkhead anyway just so I could have an exhaust duct and vent. I'm thinking insulating the bulkhead would help with my issue.
Any other recommendations? I also considered extending the bottom face of the trusses within the building to provide more space for insulation (reducing ceiling height a few inches).. It's a lot of extra work but I think it might be worth it.
DarrenF
Thunder Bay, Ontario
it probably wont be a problem, especially if you paid attention during vapor barrier. you'll be ok since you are vented, the roof deck will stay frozen, like it should.
RocketScott
Lexington, KY
I've framed a limited number of houses (2) that used a 'warm roof'. Both had TJI roofs with spray foam directly applied to the underside of the osb, no airspace for venting. I'm certainly no expert as I just framed the structure.
larry4406
Northern Virginia
In the houses the company I work for builds, we have a similar low pitch roof on our morning rooms although our ceiling is vaulted not flat. We use the styrofoam baffle to vent the soffit as traditional, but we use closed cell foam for the first 2 feet or so from the bearing wall then transition to batts. We are able to get 5.5" of foam in this space for an R-38, but that is it.
I think if you need to get more R-value, then your clipped ceiling corner has merit.
Radix2
the thumb!, MI
I think the best would be to build an angled soffit in the corner that follows the roof pitch at the required depth for your insulation. You could then blow it in at the correct depth all at once.
With 12' walls, an angled section of ceiling at the edges will not detract from the room.
