Pervsrodshop
- Joined
- Dec 4, 2013
- Messages
- 4
Been a member for a couple of years and have found lots of good advise but now that I want to insulate my garage I cannot find all of my answers. So I live in MN and I do NOT plan to keep the garage heated all winter just heated when I am out there working on my project truck. So that being said I will do R13 in the walls with 1/2" sheet rock, and was thinking about just doing R19 in the ceiling with 5/8" sheet rock. So a little back ground on the garage, when the PO had the house built instead of sheetrocking the while ceiling he had them do about 6ft out from the house then up to the ceiling to create a little attic area. Then with the remaining rock he (as I see it) randomly hung it on the walls. @ sheets on one side, and 4-5 sheets on the other side of the garage. So NONE of the wall sheets have insulation behind them. I took 1 sheet down already and 1 sheet has a built in cabinet on it and there is not insulation there either. So the other 4-5 sheets do NOT have insulation behind them. So for those sheets do I
1. leave them alone and do nothing?
2. Take them down and insulate and replace them?
Or 3.... Other option?
So when insulating my walls do I have to use vapor barrier or is the Kraft facing enough?
Then for the ceiling do I have to use vapor barrier there or is the facing enough. fyi I am leaving the little attic area intact. I plan on using R19 for the ceiling since I just want to help keep the heat in to take the chill out of the air in the winter. Then also foe the ceiling do I need to run the "air flow channels" under the insulation or can I just lay it right on the rock? And yes my soffits are vented on both sides of my garage. The PO had stuffed insulation over them to keep the cold out. I will be removing all that. I just want to be able to use the garage more in the winter and summer. I was fine working out in the garage in the winter running a 240v heater while wearing long underwear before but have saved some money to do this. So I am NOT looking to make all the seams and all perfect I just want a usable, comfortable garage to work on cars in year round. So any tips or advice would be GREAT! I am also adding more lights and fans. Thanks in advance.
