insulating radiant in house
Kaizen
New England
Struggling with a path. I ran pex in several rooms using plates in the basement ceiling. Works great. I put r19 insulation in the cavity leaving a little air gap between insulation and aluminum mount plates. Its an old house and i always get mice. seems they love making nests in the insulation. eventually die from poison i leave out and the stench of death wafts through the floor.
Water temp is 110.
options i see are....
spray foam. concerned about heat burning the foam?
cut 2inch insulation and try and wedge up between joists. still will have a mouse house gap and will ****
1/2 inch insulation across the bottom of the joists. lots of pipes so almost impossible.
anyone been through this and have a good solution? again old house, rubble foundation, dirt floor. mice are the constant in this equation. dog would like to eat cats so cat is out.
Firebrick43
West central Indiana
Some places require a fire barrier such as 5/8 drywall that taped to the bottom of the floor joist if you apply spray foam. Also if there is ever a leak and the sub floor is damaged you could have a nightmare.
Not trying to talk you out of spray foaming. Just informing. There is a real problem you have. Foam is a possible solution is just brings many down sides.
Is this a basement or crawl? I know it would cost some money but if a basement would it be possible to get a line pump hose down there and pour a floor and slip foam a 4" coat on the walls? Or even trowel a surface bond cement for a stucco like appearance.
Also check out the bucket mouse traps with a roller smeared with penitrations butter
