I just had a pole building built with 1” hemlock board siding, and now I am starting the interior work.
I am putting in a 12x16 room on top of the uninsulated concrete slab. One end of the room will sit against the posts on an exterior wall. I don’t intend to keep the room “warm” but need to be able to keep it above freezing, so I don’t plan to insulate over the slab. The interior walls will be pine tongue and groove.
How / what layers should I use to construct these walls? I have some polyiso foam board leftover from another project. Can I use that as sheathing instead of OSB, then put shiplap over top on the outside? Should I be using only the board insulation or fiberglass batts also? What type of vapor barrier do I need?
