bluedog225
I thought I’d check in before choose a method.
I’ve got some empty space on the exterior walls where the stud walls meet in the corner. The place is finished on the outside and not yet closed on the inside. The stud walls are tight against each other on the corner so I’ll need to drill holes to get to the gap. I was thinking of drilling a small hole in the top and using low expansion foam until I fill it up.
I’m aware of the dangers of using high expansion foam. Is low expansion foam the way to go? The only other alternative I can think of is to drill a larger hole near the top with a hole saw and just shove in cellulose until I fill the void. Tedious but doable.
Thanks
Thanks
