Insulating unheated attached garage ceiling - Faced or Unfaced?
kdrymer
I am getting ready to install insulation in my attached garage crawlspace above drywall that is already installed in the ceiling. The garage is not heated and the 2x4 trusses are on 24 inch centers. Do I still need Faced insulation for this application, or would Unfaced work? I am in Northeastern PA, so we do get pretty cold winters. I already have the exterior facing walls insulated with R-15 Faced. Thanks in advance.
mike93lx
Richmond, VA
Vapor barrier goes to the warm side. There must be something adding warmth or this is no reason to insulate.
billconner
Thousand Islands NYS
it won't matter a lot but the vapor barrier function of the Kraft paper will be compromised some by not being fastened to the trusses. Unfaced fibreglass or blown in cellulose (my preference) and a vapor barrier paint on drywall would be a little more effective IMHO.
Sumboodie
AK
Bit confused. You have a crawlspace under your garage with drywall on that ceiling (ie, the garage floor)
rayra
Escaped from Los Angeles
Pretty sure the OP was talking about an attic space above, rather than a crawlspace under.
The painted drywall is vapor barrier enough. Just get unfaced 24" batts and call it done. Go for at least R19 and maybe even R38, running a second layer of R19 crossways, if you can afford it.
Sumboodie
AK
To meet energy ratings here (and it's SOP) 6 mil plastic goes between the studs and drywall as a vapor barrier. I've never heard of paint being able to act as that.
That being said, probably fine without in a garage, even more so in a temperate climate.
CombatNinja
OP, what is the goal here? Just trying to control temps a bit more for part of the year or what? Ultimately, without HVAC insulation will not really do much.
TractorJeff
Elkhorn, WI
AH! But maybe he is doing this project in financial steps?
Walls are insulated, definitely insulate the ceiling!
Unfaced would be easiest to put in.
If the Kraft paper cannot be sealed, then no reason to use it is also my OPINION.
toolmiser
La Crosse, WI
Somebody will correct me if I am wrong, but I've been told by an "energy consultant" that fiberglass insulation doesn't prevent air movement so something like cellulose insulation will keep the air from flowing out thru the insulation. I would recommend either getting a blower or having someone blow all the insulation in your attic. You will get a better job.
K'ledgeBldr
Johns Creek, GA
For an unconditioned garage- insulating the attic will certainly retard heat gain during the summer, and would probably help retain vehicle heat in the winter. But, I certainly wouldn’t over-do the insulation- the ROI isn’t there.
And I certainly wouldn’t have spent the money on the walls- unless there is a possibility of adding heat&air down the road. But why?
Sumboodie
AK
I have a fully insulated, unheated, attached garage in WI., it is usually 20 degrees warmer inside the garage than outside during the winter.
I insulated the walls in my 16x20 shed before sheathing it. Figured it was much easier to do then, vs deciding later and having to pull everything down and rip down OSB
jsaw
Geneva, N.Y.
In the winter my insulated unheated garage will stay above freezing unless the temperature is down around 0 or 10 degrees for longer than a week or so.
CombatNinja
So you're saying it's 15 degrees in your garage in the winter. Got it.
