Insulating walls in metal building.
bigboost
Jacksonville, Florida
So I'm starting to think up ideas of how to cost effectively insulate my building, starting with the walls.
I'm not really a big fan of the spray insulation, at least for the walls, I think it looks horrible, not to mention is expensive.
When we mounted my fuse panel this idea came to me, not sure if it's a good one, i'll leave that up to you.
I thought about just putting some ~R20 fiberglass against the wall and then mount the plywood flush with the purlings. It would also be nice as I could hang things from the wall easier.
Any input?
aka Larry
Eastern, NC
My building has the same construction so I'm interested in the responses as well.
I was thinking of 2" thick rigid foam, but don't plan to cover it.
bigboost
I considered the rigid foam as well since I wouldn't have to cover it, but the R value is so low I really don't think it would do me much good as far as trying to heat/cool it.
Having 12' walls and 16' gable is going to prove challenging enough to efficiently heat/cool it haha, trying to get all the R value I can.
aka Larry
Eastern, NC
Agreed, but with only 2" of space (in mine) there aren't many options.
kj_mustang
Harrisonburg, VA
Rigid foam is a fire hazard too even with the fire retardants that are put in XPS. You should have a thermal barrier over foam.
Dirtygrunt
Hey guys I have the same building design as larry and am also looking at insulation could 2" rigid foam be used and covered with osb board
