doyle4281
Hello all, I recently purchased a Daikan mini split for my attached 3 cat garage/workshop, and could use some opinions on the matter of insulation. The walls are not a problem, it the ceiling that is an issue. The garage has a multiple roof angles, which leaves many rafter bays essentially unventable. Short of drilling holes through the ridge beam to get airflow from neighboring rafter bays which have soffits, I don't know how to properly install the installation. I could use closed cell spray foam and create a complete unvented ceiling, however that stuff is very expensive. My intention was to install unfaced insulation between the rafters, and then cover with 1/2 poly iso rather than drywall. Any suggestions?
