Insulation and heat
Blkctsv05
So I started my walls an drop ceiling build in my garage to keep heat an a/c in. I laid my r-13 in ceiling an I have a radiant tube heater 4" from ceiling that's the dimensions it says stay away. My problem is I had it running an I noticed the paper of r-13 turning black from the heat so it's getting hot. But I'm also using styrofoam 1/2" board with reflective Shiny foil faced above over the insulation will this be fine?
Dragster Racer
Morrison, IL
If it is turning black I think that tells you something. I don't know that I would trust the foam board at that distance either. I would be tempted to at very least put a sheet of corrogated metal sheeting above the heater.
Fueler
Urbana, IL
That might not be directly heat related. What about moisture turning the paper? Seems to me if it was heat that the paper should crumble to the touch. Either way further investigation is warranted.
harvero
Flemington, NJ
What is the heat source of your tube heater? Is it external like a water heater, or is is a gas or propane fired heater? If it is one of that latter, then is there a external exhaust, or does it vent inside?
Blkctsv05
It's a propane heater with vent an it has a sheild so drywall would be ideal?
Highbeam
Mt Rainier foothills, WA
Clearance to combustibles means clearance to combustibles. It doesn't matter if that is balsa wood or sheetrock. If you properly measured and met the required clearances then something may be broken causing a hot spot on the heater.
I would not be happy if the combusibles located outside of the minimums were charred.
bczygan
DETROIT! Arsenal of Scrappers
Let me be very clear.
I just looked up an installation manual for an infrared tube heater. They have very specific instructions for mounting as we as what materials can be placed near them, and how close these things can be.
Get a copy, or look one up on line, for exactly your make and model. Read and follow all instructions exactly.
Personally, I would like a non-combustible shield or material of some kind, above the heater, even if the heater had it's own shield. But the instructions I read did not specifically say that. I've experienced the loss of a building from a heater, so I'm a little gun shy. Not a bad thing.
Bill
Blkctsv05
K
[/IMG]
Fueler
Urbana, IL
I think you will be fine with the reflective material. If you want to experiment, take a piece of the materials in question, set it in front of an open oven and say set it for 100 degrees and see what it takes to discolor it.
I suppose you could also look up facts on the material and see what it's combustible point is.
