I have a 48’x56’ pole barn that has blown in above the ceiling and spray foam in walls.
Inside the shed is a 16’x32 kitchenette/bar area. Inside that is a 8’x10’ bathroom.
The shed part will not be heated full time. The living kitchenette will have heat and AC but used on an as needed basis. It will be kept at 45 degrees in the winter though. The bathroom will always have heat since that is the main plumbing area.
What type of insulation and/or vapor barrier should be used in the shared walls? I’m leaning toward batt insulation but really unsure on the vapor barrier stuff.
Thanks for any insight.
