I have a shop building that has trusses placed on 48 centers. In my area, most buildings have trusses placed on 60 inch centers but I specified 48 inches. I put 1.5 inch foam sheets between the purlins and then double bubble foil and then the metal. I then covered the purlins and the foam sheets on the inside of the building with 1.5 inch foam sheets.
That left the trusses open for me to use for storage.
I am VERY impressed with how it insulates. We've had some upper 80s and a few 90+ degree days with the sun shining directly on the building. I went to the shop and checked the temp inside. It was about 68 degrees....about the same temp as the concrete floor. Basically, there is very little heat gain in the summer and so the shop building stays very comfortable even completely closed up. I'm a BIG believer in foam sheets. 3 inches of foam prevents most of the heat gain/loss.
1.5 inches of foam isn't quite enough by itself...there is still some heat transfer through the 1.5 inches foam...but 3 inches is more than plenty for most climates.
Here's a pic as it was going up:
